I have a 1949 Case sc with a Fairbanks Morse megneto that still wont spark. I took it to a tractor store to have it looked at and they replaced the cap on it because they found the copper ring inside was loose. After setting the timing on the fly wheel, I put it back on the tractor and it wouldnt start. it appeared to be not sparking. So I took it back to the tractor parts store and they bench tested it for spark and said it looked fine. I put it back on the tractor and it still wont start. We took it off and hooked a wire and plug to it and manually snapped it around and got 1 or 2 tiny sparks and that was it. im at a loss as to why it still wont work. any help would be appreciated, thanks
