actual volume in quarts
Does any one have on recall the actual volume in quarts for the rad ONLY: not the whole cooling capacity ; for a super A rad. I need to mix a cleaning solution of muriatic acid and water to clean out scale in the rad only. I could take it to a rad shop for $60.00 but would like to try myself first, with a mixture of water and acid. Found a method on line earlier today I would like to try first. Yet I need the volume in quarts for the rad.
Thank you;
Wm.
(quoted from post at 15:39:03 08/09/17) Does any one have on recall the actual volume in quarts for the rad ONLY: not the whole cooling capacity ; for a super A rad. I need to mix a cleaning solution of muriatic acid and water to clean out scale in the rad only. I could take it to a rad shop for $60.00 but would like to try myself first, with a mixture of water and acid. Found a method on line earlier today I would like to try first. Yet I need the volume in quarts for the rad.
Thank you;
Wm.
ow about you count the number of quarts that you dump into it to fill it? Seems easy.
