1946 BN IHC
Good morning all in Ontario, Michigan, in particular but also those in and around Lancaster Pa and Cleveland or Toledo Ohio.
Does any one have a scrap IHC trail plow that I may collect the following parts for re furbishing the two furrow IHC 8C adjustable beam tractor plow I just aquired.
I need the lever wire clamps.
" preferably "4 release levers latch [steel] for the tops of the control leavers;[part number SA 2022 according to my manual]
A long land side [part number SA 6108A with heal or SA 3873A for the furrow plow bottom [ my owners manual describe them as rear bottoms ace or rex - 10 - r of 9" through 11" blade with heal] it also appears that a brace bracket is also needed.
I am rebuilding a 2 furrow pickup type plow from a two furrow three wheel to replace one that was stolen from me.
The parts preferred to be in reasonable shape thank you.
thank you for all your assistance.
You may write me and even send pictures of the parts to my email or text me the same to 519-615 0412
This is a winter late spring project SO I am not in a panic
Thank you again for any and all the help set forward.
Wm.
Wm.
