what causes uneven clutch lining wear??
a while ago I had clutch problems on my 1960 single clutch dexta, when I pressed the pedal down it would not stop and today I split it to fix,i soon found the problem one of the pins on one clutch arm had dropped out but I was surprised to find uneven wear on both clutch linings, the inside of the flywheel had worn more than the outside and the opposite on clutch cover side.. before the pin dropped out the clutch was ok..the hour clock stopped at 8500 hours so it has done about 9000 hours, the flywheel face has hardly worn over 57 years .. it has had an easy life
