Allied 395 loader on JD1020
treeninja
New User
Hello everyone. I'm new to the forum. I'm having issues with my loader. The bucket will curl and lift the tractor off of the ground. The bucket will raise slowly but will not lift any load. My three point hitch works fine. Also can't disconnect outside quick connect that works the lift. Valve is a Cross "B" series valve. Any help would be appreciated.
Here are some pics of the setup.
I had the same problem,and so did somebody else down on the Oliver forum. The seals in the center of the lift cylinders were blown. Oil was passing right by and back in to the return.
Open centre or closed centre valve ? Is there a relief valve and what pressure ? 100% certain that the correct ports have the flow in the proper direction?
High pressure or low pressure cylinders on the loader? Seals can fail in one direction and hold on the other direction.
You will find operation of the loader much superior if the SCV's are left for raising cultivators etc.
Supply the loader valve direct from the high pressure line supplying the SCV . Return the loader oil to a ported filter cover . Otherwise the front pump runs out of oil.
(quoted from post at 15:57:44 07/31/17) When you raise the bucket, will it stay up, or does it come back down on it's own?
Thanks for the reply. The bucket will stay raised until I engage the valve to let it down.
