i need help on a tractor injection pump ...i had some small leaks and removed pump to replace all light gaskets i could without diving into pump , before i removed it it was pumping fine .
so after installation just like it was it wouldnt start tractor . i bled all line and did everything i have done for past 20 years . when i opened the bleeder screw and turned it over to bleed it used to spray out 3 feet ...now it was just drizzling out ...
removed all fuel lines to make sure i was getting fuel all good . then a mechanic said it was hooked up wrong . that the fuel filter assembly was pushing fuel to 2 separate ports the pump end and the middle of the pump labeled #3 ...so he bypassed the fuel out in #1 and said that #3 was an over flow and shouldnt be hooked to the pump ...tractor started right up
its been hooked this way for years and ran and all pics i see on web is like mine , i think there is something wrong or something small not working please help
[/img]
