I WAS REPLACING THE NEGATIVE BATTERY CABLE ON MY INTERNATIONAL 364, NOTICED THAT A SMALL WIRE COMING FROM THE VOLTAGE REGULATOR WAS BARE HERE AND THERE NEAR THE POINT OF HOOK-UP, SOMEONE HAD MOUNTED A BATTERY CUT-OFF SWITCH TO THE BLOCK . THE NEGATIVE BATTERY CABLE AND THE PARTIALLY BARE WIRE COMING FROM THE VOLTAGE REGULATOR WERE CONNECTED TO THIS CUT-OFF SWITCH...THAT IS THE WAY IT WAS WHEN I TOOK IT OFF. I REPLACED THE NEGATIVE BATTERY CABLE AND THE SMALL PARTIALLY BARE WIRE AND WHEN I WENT TO START THE TRACTOR I HEARD A CLICK...AND THE SMALL PARTIALLY BARE WIRE "ARC-ED" ON THE END OF THE NEW BATTERY CABLE... AND I HEARD AN AUDIBLE CLICK. NOW I HAVE NO POWER GOING TO THE STARTER. IS THERE A FUSE BLOCK ON THIS TRACTOR...IF SO I HAVE BEEN UNABLE TO FIND. ANY ADVICE WOULD BE APPRECIATED!....
