lastcowboy32
I didn't have a socket big enough to fit the outer race, and there wasn't enough of the race showing to get a good shot at it the edges with a punch.
I did have a socket that was close, and I have a tapered cold chisel. I set the socket on the bearing. Set the chisel next to it and tapped it a couple of times to wedge the socket against the far wall of the bearing housing, so that it had a good bite on the bearing's outer race.
Then I held the chisel in place with one hand; while I hit the socket with a four pound hammer with the the other hand. I had to rotate the housing a few times and reset the socket and chisel to alternate the sides of the bearing race that I was hitting and work the bearing out evenly. But I got it.
