trentorosz
Hey there I have a 750 ford I bought and didn't pay very much for
It runs great fires right up but when I shift into forward or reverse I lift the rear tires off the ground and rev it up to half- 3/4 throttle and it takes a good minute or two before the fluid fills the torque converter and takes off
Once it's running it pushes into piles fine and drives alright and goes forward and reverse fine but if I shut the machine off for 5 minutes and come back I have to redo the same procedure
Bad torque converter or is there a pump I'm missin a drain valve stick open?
I pulled the filter and started the hoe and it pumped fluid instantly to the filter housing
I also changed the filter and no difference
