TN65 New Holland 2003, Remote Hydraulic Leak
Glen_N_SC
New User
TN65 New Holland 2003. Remote banjo bolt leak... Need expertise/advice! Have a 32LA loader remote. The seal washer on the banjo bolt began to drip, then sprung a leak. I replaced the Banjo bolt seals now 3 times and I cannot get the leak to stop. The seal washers are M22. I bought a new banjo bolt. No solution. Tried tightening low torque and high. No solution. Swapped to brass washers. No solution. Now I considering replacing the tube/line that the bolt goes through, but can't understand why this would be the issue. Is there some check valve or other component that might be causing over-pressure? Other suggestion of experience would be most helpful. Thanks.
Well if you changed the washers and bolt and it still leaks probably the banjo itself. Some have ridges on the face to help it seal.
Don't know about pressures.
Thanks. I was thinking about replacing the tube (banjo fitting.) But, as many of you know, chasing a fix can cost money when you don't have a
real idea if that's the issue. But, on the other hand, what else could it be?
I'm wondering of there's a crack in that fitting?
Did you run the new bolt in without the fitting/line in place to make sure the bolt is not bottoming out?
I bought a low hour TT60A and had a similar issue. I think the original owner lived with it, as if not worked under pressure, it didn't leak much. It started to baffle me. I could see where a new washer was not squeezed evenly. Turned out the threads were so poor in the housing it would cross thread slightly, AND where the relief was machined into the bolt/adaptor for the washer, it wasn't machined quite small enough for the washer to set down square and tight like it should.
(quoted from post at 21:26:33 06/16/17) [size=18:e796ef341b] I'm wondering of there's a crack in that fitting?[/size:e796ef341b]
Had one on a TD-16 injector pump doing the same thing ,after replacing the seal a few times (on the back of the pump) finally found it to be leaking and cracked at the joint between the fitting and tubing. took the line off and had it re-welded / brazed and all is well.
Problem solved. The issue was a cracked hydraulic tube at the banjo fitting. I purchased a replacement tube and new seal washers. The replacement took about 3 hours and is a bit of a hassle. However, it was the source of the leak. This now answers why replacing the seal washers alone was not a valid solution. No matter how much the banjo bolt was tightened, the crack just got worse. Thanks to those of you that offered help with this.(SEE PHOTO).
<image src="http://forums.yesterdaystractors.com/photos/mvphoto418.jpg"/>
