1964 case 430 3 point hitch problem
Hello everyone, I just bought a case 430 with a front loader and John Deere 503 pto driven mower, we have a problem with the 3 point, every time we try to lift it up, itvspews oil everywhere from the breather under the seat, but only when you raise it up, then when it is up it goes down then jumps back up, it does this repeatedly until you put it back down, when it jumps it leaks oil from the breather, its weird because nothing is wrong with the loader, please help, we need the tractor fixed
Sounds like the packings are gone on the 3pt cylinder, and the PO added oil until the entire front hyd. resivoir and the rear gear case are full to the top. The leaking oil is now coming out the vent.
Scroll down to the Case forum and post there. The guys there will help with further info and possible other problems to check. You need to get all the extra oil out, or you will have bigger problems.
Loren
Thank you for the reply, never worked with old of tractor before, and thank you for pointing me out in the right direction, new to the forum haha
