bent oil pan 641 workmaster
jdcook
Bumper fell off and dad drove the tractor over it. It wedged the bumper under the tractor pushing the oil pan up about an inch in the center where the drain plug is.
After getting the bumper out from under it. I cranked it up and heard some tapping. I am assuming I need to take the pan off and beat it out from the inside. How much
clearance is under there? Should I be looking for a different problem? Just got the other tractor running and now another project.
Thanks
Dave
It will be a straight forward 15 min job, provided that you have a replacement gasket for the plug. and don't go goobering a tube of silicone seal on the main mating surface. Just a thin film only if it needs it.
