TN65 New Holland 2003. Remote banjo bolt leak... Need expertise/advice! Have a 32LA loader remote. The seal washer on the banjo bolt began to drip, then sprung a leak. I replaced the Banjo bolt seals now 3 times and I cannot get the leak to stop. The seal washers are M22. I bought a new banjo bolt. No solution. Tried tightening low torque and high. No solution. Swapped to brass washers. No solution. Now I considering replacing the tube/line that the bolt goes through, but can't understand why this would be the issue. Is there some check valve or other component that might be causing over-pressure? Other suggestion of experience would be most helpful. Thanks.
