IH B275 1961 clutch pedal
Greetings
My clutch pedal spring seems to be
really tight. To the point where my knee
is in pain after using it for a few
hours. Have any of you experienced this?
Any way to remedy this? Change the
spring for a softer one?
Thanks in advance
You need to ascertain if it is the clutch shaft hanging up, or the clutch fingers on the pressure plate. Also make sure adjustment is not off and you are disengaging both clutch stages at once (engine and PTO clutch). There is a grease fitting for the clutch pedal shaft.
