I have a John Deere 24WS small square baler, I bought it this past fall and the seller said it works fine but sometimes it would not cut the wire right on one side of bale. Well the problem is that now that I am trying to use it every other bale the inside wire will not stay connected to the gripper so that it can be twisted to the other end of the wire to keep the bale together. And this only happens every other bale, the next bale ties up just fine then the next one is bad with out fail. I have been trying to figure this out but no luck, any help would be very much appreciated. Thank you very much.
