Power Steering pump
mayorbob
New User
I need pictures, schematics &/or directions for removing and working on my power steering pump. Had the single cylinder checked out by a hydraulic shop, & they said it worked just fine. So I need to remove & rebuild pump & get new filter (or replace the filter). I have the single cylinder set-up with steering shaft that goes from steering wheel to front of the tractor (not the hydraulic unit at the steering wheel & 2 cylinders like my tractor manual shows). Evidently this is a farm tractor, not industrial tractor, but with backhoe & bucket. Any information would help. Thanks... Bob
1962 Case 530 SL . Sorry I didn't post tractor info...thought I was following up on a previous post. I'm new at this!!
As we told you before, you need to diagnose the problems before you start tearing things apart. Put a pressure gauge in the line from the pump and see what you have for pressure. The service manual which you need to have will tell you what pump pressure should be.
I presume that you have got the tractor to move now.
Your tractor does not have the same steering as an Ag unit either.
Loren
