I am trying to get a Massey Ferguson 65 running that was sitting for a number of years. If you spray a very small amount of starter fluid it will start quickly and run briefly. We rebuilt the fuel injector pump because it was not pumping fuel to the injectors. We now have a strong supply of fuel to the injectors but it doesn't even try to start. I was careful to photograph the timing marks before I removed the pump and to bolt the pump back with the same settings. What should I do next? Do injectors corrode with time and go bad? Could the pump timing be off so much that the injectors would not fire? If I decide to replace the injectors who makes the best quality replacement injectors? I plan on keeping this tractor for a long time so I want to use the best parts. The person I bought the tractor from had pull started it and had the engine running.
