Does anyone make or know someone who makes governor linkage rods for tractors? I know they are simple steel rods with some threads and a hole drilled; but I don't have the time to make them nor do I have a drill press to drill such a tiny hole. In specifics, I need the "Governor-to-Carburetor" linkage rod for a Farmall 140 tractor. I believe they are the same for the Super A, 100, and 130 tractors too; so I would like to get about (10-12) of them since I would be getting someone to make them. The reason for needing is because the old ones get rusted and snap in half when trying to adjust them. I have a Farmall 140 that I restored and I'm putting it back together and need one for it. I would also buy about (12) rods for a Farmall Cub (same design but smaller) tractor too.
Please let me know if you or someone you know could help!!
Pictures attached below of an original NOS linkage rod for a Farmall 140 tractor (minus the jam nut and clevis, which can be bought through McMaster-Carr)
