Michael Price
On the bottom of my case 1070 where the axle bolts to the transmission there is a crack that someone tried to weld and then the crack came through the weld so then they put a epoxy like JB weld on it. I would guess its about 6in long. It leaks enough to where I need to fix it. Any ideas how to fix it?
I was going to try and just use a air chisel to pinch the crack shut but not sure if that will work since its been booger welded.
