Farmall 230 compression
MavR
New User
I'm redoing a farmall 230 and was wondering what the compression should be for it. I don't know if it helps but it's a c123
Redoing as in what??? If your doing a complete engine rebuild then the compression you start out with will be a bit on the low side since the rings will not be broke in since that takes time. A good running engine in that class should have around 125PSI give or take a bit. Now if your just trying to figure out how good or bad it is if you have lower then say 100PSI it might be a bit on the tired side. I do not have exact number since I do not have the compression number in front of me plus the exact numbers are hard o come by as such since compression is lists as a ratio not in PSI
