Case 930 three point repair
porfrm
New User
Hi I'm knew here so bear with me please. Have a Case 930 CK Draft o Matic. Was using mower on 3 point and long story short caught mower on left rear tire lug. Lifted mower high enough to hit fender. No visual damage to 3 point. Not wanting to lift or have down pressure properly now.I removed plate under fuel tank and linkage in there looks fine. With arms all the way down And tractor not running I am able to lift arms . is that normal? Ideas as to what to look for to fix? Could hydraulic valve been damaged? Thanks Fred.
To start with a 930 NEVER had down pressure on the 3pt. It sounds like when the tire caught the mower that it raised the hitch so high that the "donkey dong" (a connecting rod attached to the rock shaft, but not to the lift piston) fell out of the lift cylinder. You will have to pull the rear PTO housing and see if you can get the donkey dong back into the cylinder bore if it didn't break something.
Scroll down to the CASE forum and post there. The Case guy there will walk you through the repairs, and Dos and Don'ts when removing the rear housing.
Loren
(quoted from post at 09:59:28 04/08/17) To start with a 930 NEVER had down pressure on the 3pt. It sounds like when the tire caught the mower that it raised the hitch so high that the "donkey dong" (a connecting rod attached to the rock shaft, but not to the lift piston) fell out of the lift cylinder. You will have to pull the rear PTO housing and see if you can get the donkey dong back into the cylinder bore if it didn't break something.
Loren
Thank you I will check with Case guys.
