I have a 1948 Ford 8n. Before this ticking/knocking sound started the tractor would pop out of reverse either on a bump on the road or when I pressed on the clutch pedal ( engaged)
Now the tractor makes a loud knock/ticking sound anytime the clutch is not engaged. I pulled the top cover and drained the oil. From what I can tell is the lower shift rod(I think that's what it's called). What is that rod connected too? Any ideas as to the cause of the problem?
I've taken a video
I've taken a video
