drag link with aftermarket power steering
w6rpm123
New User
have a 57 851 with aftermarket power steering and found out the hard way that when powered by the loader hyd. that the new designed drag link is not ridged enough to handle the stress that is put on them. so bought another set but this time I put a 5/8" cold roll shaft inside the tube and so far that seems to have been the answer to bent drag links. hope this helps others with this problem.
Ron, Valley Springs,Ca
