1969 John Deere 112
Alex Duncan
New User
I am currently restoring a 69 John Deere 112 the serial is 131599M and the type is TO656. I have ran into an issue with my local John Deere store they can't find the right belts. Does anyone happen to have the correct numbers for the primary, secondary and the hydraulic belt?
Absolutely NO guarantee on these results, the JD parts web site for your serial number 131599 tractor leads to:
Book # 1080 serial#'s (100001-250000)
Alpha Index
Sec B
Belt Drive
#2 Secondary (sub) M42250
#19 Primary (sub) M43095
Sec P ( hyd belt is hidden here)
Pump Hyd (in line )
#7 M43106
Do these compare to what you have been told ??
(quoted from post at 04:01:35 04/04/17) Absolutely NO guarantee on these results, the JD parts web site for your serial number 131599 tractor leads to:
Alpha Index
Sec B
Belt Drive
Pump Hyd (in line )
#7 M43106
I haven't been given those numbers yet I'll check them out and see if they will work. Thank you for all your help
Look on the Weekendfreedommachines website, or on the WFMFILES website.
The belts are:
M82258 primary (SUB FOR M43095)
M44121 secondary (SUB FOR M42250)
M43106 Hydraulic - Tecumseh
This is if your tractor console has the original tag and your model number and serial number are correct.
It's 48 years old and things happen.
