MF 135 PTO Problem
I have a MF 135 diesel tractor. The PTO will turn without implement attached but will not turn when attached to shredder nor will it lift attachments. Any helpful advice will be appreciated.
If it's the two stage flywheel clutch you may have the PTO disc center rivets sheared, or severe disc lining wear. It drives the hydraulic pump, and the PTO output shaft is splined to the back of the pump.
