Ford 9n water pump
1941-Ford
New User
I have a ford 9n and when I get the engine above idling speed the water pump starts to squeak. I know its the water pump because i have sprayed PB spray right behind the belt pulley on the fan. When i do this it will quite down for a little while then squeak again. Can i fix this with a water pump lubricant or do i need to get a new water pump? I know the pump works becuase the radiator does get pressurized.
Water pump has nothing to do with pressurizing the radiator! Temperature does that. Be sure it isn't a fan belt squeak.
