Transmission fluid
colsonpeewee
New User
What type of transmission fluid is used in a 1960 fordson dexta and how much does it hold? Also, where can I get a manual that contains all the info about this tractor.
Where do I put in hydrolic fluid?
One place to get an operator or a service manual is Jensales...just google the name. Usually operator manuals ID all controls, fill and drain points, lube specs, etc. Service manuals tell you how to dismantle and fix things.
not sure of the dextra but if it has hyds that use the gear box oil like the 8N tractors it will use its own kind of oil made for that , tractor supply
does sell it , not much more cost then any other oil
