removing ford 2n brakes
Drill the heads off is another option. The wheel actually holds it in place. The bolts really are not needed and a lot of people leave them out. A impact driver is another option but you may be past that since they are stripped out, good luck.
"Drill the heads off is another option. The wheel actually holds it in place."
Del, I believe you are thinking of 8N brake drums. The 2N's are set up altogether differently.
