Stuck in a higher gear
Sheard pin in transmission stuck in a higher gear .
Am I gona have to take the whole cab off to get to top of transmission .? To see if pin is sheard .the nuckle is intacked not loose .starting to vibrate so I shut it down
Oh yes well this is a newholland 06 back hoe with cab. Sorry.
I beleive the flywheel is the vibrations starting and now I have it stuck in a lower gear by jacking with it ... I took fuse cover off noticed some wires had been chewed on .mice. thinking maybe has something to do with it. the newholland only has 1100 hrs on it. . The flywheel has three plugs in it .as of one missing as ive just noticed . And were I can here yhis tapping vibrations cumin from
