Changing Hydraulic Oil
My daughter recently purchased a 1974 farmall 140. It was my job to bring it back to life. After checking the rear differential oil I found that it was 1/2 water so I changed and added oil. I checked the hydraulic oil for the touch system and found it low. Everything works but since I found water in system I thought I would change all fluids. I am not sure where the drain plug is for hydraulic system. I know there the fill plug is could the drain plug be the plug to the lower right of fill and check plug.
