I read Several threads concerning low oil pressure related to warped oil pump cover plate and blown gasket. I took a chance, dropped the pan and pulled the pump and sure enough that looks like it is a problem. I have flattened the cover surface and reinforced the cover plate. I'mean ready to Reinstall everything but need some advice concerning the gaskets for the pump cover and oil pan. Should I use tube sealant for Both? The pump cover gasket is paper thin. The oil pan gasket is much thicker and judging by how hard it was to remove and get clean I'don't say yes or the pan. Just want to do the job of explaining time.
