JD Model 2630. I just bought this tractor and have replaced several bulbs, lights and have found that the light switch was bad as well. I have a new 5 pin switch
but have two problems. First, a couple of the switch wires were loose from the switch, and secondly, I suspect that some of the wires were installed on the wrong
post. Could someone share information that would give me the proper wiring sequence? I have attached an image of the 5 pin switch. Thank you. Stan
