Lowering mf 65
Hardluck
New User
Will 11/24 work on high crop tractor . Also I've got xle knees off what I think is a 35 . Will they be strong enough
Don't think the 35 front parts are what you want, I'd use 65 standard axle ends. They are shorter than row crop, and will fit the center section where the 35 ends won't.
I've been having problems trying to find used 65axle knees . But I can get new 165s . You think they would work
the 65 I got is a high crop . I'm lowering it . I got some 11/24 but I think that'll bring the back end to low . Replacing the front axle with 165 axles do you think it'll bring it to the level position . Or should I get 14/28 .
