I've had this tractor for a little while now, and I got around to checking the steering, and there was no fluid in the box. So I filled it up with 80w-90. In 2 days there was almost no fluid in the box, it all leaked down the sector arms.
Its got what I think is called power-assist...its got two hydraulic cylinders attached to the tie rods.
So I ordered some oil seals for the sector shafts. Took the arms off...and could not figure out how to remove the old seals. I took off the cover and adjusting screw assembly from the opposite side. I could tap the sector arms back and forth 1/2" or so, but they wouldn't come out.
So, is there some method I'm missing (the manual says they just pull out...not so...)
Or should I put the #00 grease in and save the oil seal parts for another decade....
