1989 J.D. Power steering line blows
Richard 5678
New User
My John Deere skip loader keeps blowing a line that runs from behind the steering wheel down to the frame.Its a half inch line maybe a return line looks to be low pressure. No steel in this line I cut in a hose mender and now the hose blew in another spot. I'm thinking some thing is frozen and causing pressure build up.
I have basic knowledge. Was wondering what you think the problem is?
You might as well toss us a bread crumb or two here, and post the model # of your John Deere "skip loader" that has a steering wheel.
AFAIK, the owners of this site don't charge extra for posting a little more detail.
Lots of really poor made hose out there. Replace the complete line with one of better quality.
(quoted from post at 21:24:23 01/17/17) You might as well toss us a bread crumb or two here, and post the model # of your John Deere "skip loader" that has a steering wheel.
Sorry for being so vague. It's a 1989 JD 210C
I did end up replacing the 400 psi OEM line
With a 300 psi after market and it held.
I did also remove a hydraulic block of some kind and
Warmed it up and reinstalled it . Then dumped the milky oil and added some fresh oil. Then I will run it and change it again and the filter.
Then on to figuring out what's wrong with forward.
In the shuttle shift (borgwarner) I suspect forward clutch discs shot. I have replaced that oil and cleaned the screen
Still trying to manipulate this site to post my pictures.
I will go to another location on this site to learn how to use
It better.
(quoted from post at 11:09:34 01/21/17) It should have a relief valve. Is that stuck closed?
It's working now. The oil was milky and its cold here
So I changed the fluid and warmed
The relief valve.
Thanks for asking
The relief valve.
Thanks for asking
