Installing dry sleeve
dacaseguy
I need. To install a dry sleeve in a Perkins 152. The last one I did, I put the sleeve in the freezer over night. I need to install this one today, I know dry ice works? I read to use acetone also. How long does the sleeve need to be in the dry ice before installing. Thanks Dick
The ones that I put in one Ford once just dropped in. I had to use sleeve sealer to keep them in place.
Never used dry Ice with acetone but have installed hundreds of sleeves and bushing In my work. Dry ice was our second choice most places had liquid nitrogen. With dry Ice I always waited till I could see frost on the sleeves or bushings and time would vary depending on the material and the size of the part.
Byron
