Bought a 1951ish MM RTU, was sitting outside for 10 years, did not run. Engine was free, took off carb, cleaned, filed points and it fired right up. I have changed all the fluids, hoses,
rewired, painted, etc. It will run and idle great, but it doesn't have a whole lot of power. Now I have a Massey Harris 30, Farmall H, John Deere MT and all of them seem to have
WAAAAAYYYY more power. If you are pulling just a running gear, no problem. I loaded a full 200 gallon water tank on it and it had a hard time getting around. It doesn't seem to want
to pull a load of any kind. I want to use her for mowing here and there as well as the occasional wagon pulling. Not sure what to do here. Governor is free and moves when under
load, but doesn't do much. Thoughts?
