ford 601 brakes
luna630
I am replacing brakes and inner and outer axle seals. My problem is pin holding brakes on left side. The two pins on the right side pratically fell out with little beating. I have been spraying CRC on the two pins on the right side and beating with hammer and 1/2 inch extension for two weeks but no progress. The top pin has barely moved and I don't know how I am going to get a swing on the bottom. Any advice appreciated.[/list][/b]
Heat and ATF. Heat hem up pour some ATF and heat some more. I have found for the price and what it does ATF will free up most stuff faster then any other thing will plus when you add heat it does it even faster
Old has an excellent suggestion. If you don't have a torch try a hammer drill set to hammer only. Don't use a drill bit, use a bar or if its an sds style get a driver.
