This message is a reply to an archived post by Jake Gower on September 18, 2009 at 13:02:30.
The original subject was "Re: P.S....".
Were you able to find anything out on removing that shaft that goes into the cam gears? I'm running into the same issues. There is a small hole or Allen screw but no way am i pulling off the dampner to get the timing cover off. My pump is already out as well.
