Hi Everyone,
I am new to mechanics and tractors, so bear with me please and any way you can help would be much appreciated.
I recently bought a Ferguson TO-20 tractor, and shortly after it began to experience and issue where it would stall out shortly after starting. I saw that it had a very weak spark so I did a complete tune up (plugs, wires, distributor) put in a new ignition coil (6v with a resistor) and though it really doesn't have anything to do with spark converted it from 6v to 12v (battery, alternator, wiring). When I tried to start it, it still wasn't running smooth so I pulled the carburetor, and dipped it in a parts cleaner for about 1/2 hour. It ran beautifully after that for about an hour moving dirt with the bucket. So I then put on my finishing mower to take care of my property. I went about 50 yards in fairly light grass, and it started sputtering and smoking. I put the mower in neutral and opened up the hood and the tractor started backfiring so I turned it off.
I though maybe one of the cables was bad, and a cylinder wasn't firing. I found a wire that a little spark was coming out of and replaced it. I stated up the tractor and it was still running very roughly with smoke coming out of the exhaust. Some smoke was also coming out of this smaller 1 inch pipe on the opposite side of the engine from the exhaust (I never noticed before, and I don't know what it does). The engine started backfiring, and then turned off by it's self. Now engine wont turn over at all.
Does anyone have any idea what's going on????
