Noticed over the summer that the fan in my 1510 had some play in it. Since it's gotten cold (upstate NY mountain cold) I believe the radiator fan is actually making some contact with the shroud surrounding it. Not sure if this is from the cold temp or the bearing getting worse. This tractor doesn't get worked too hard, probably not more than 100hrs a year.
From my repair manual, it looks like the bearing is in the water pump assembly. Is that right? Is there anything else I should check before putting a new pump in?
The repair will likely wait until the spring. Thanks for any advice.
Nate
Nate
