notajohndeere
New User
Ok so I double checked all the linkages going from the throttle to the governor and from the governor to the carburetor and all looks like it should be. Tractor is running fine but when I let go of the linkage going from the governor to the carburetor it will instantly push the carburetor to full throttle. The throttle lever is all the way back. It does seam to slow RPM's when I push throttle all the way forward (as long as I along side the tractor to move the linkage back down. Should I be looking into the governor to see if there's a problem in there? Please help!!
