gotdew
New User
I'm new here so i want to say hello. I am working on a Case SC tractor and was hoping I could receive some help with the torque pattern and specs for the head bolts and also the torque on the rocker arm assembly. From what i have found is a 60-65 ft. lb. torque correct for head. and 20 ft lbs. on valve rocker arm assembly. Thank you
Send me an e-mail and I'll scan the page in the I-T C201 manual that shows which bolts to torque first. Hard to post it here and have it so you can read it
I cannot do it that way you have to send me an e-mail. If your on modern view click my name and it will go to safe mail or if on classic click the send e-mail at the bottom of the box
This is scaned from Case S series service manual.
Loren
The generic pattern for head bolts is start in the middle, work to each end alternately, also switching side to side as you go.
