STUCK CLUTCH 2N FORD
grizz02
STUCK CLUTCH 2N THIS WORKED FOR ME REMOVED STARTER SPRAYED BRAKE CLEANER WITH A 90 DEGREE FITTING ON THE CLUTCH DISC CUT A BLOCK OF WOOD TO HOLD DOWN CLUTCH PEDAL TOOK A BRASS DRIFT AND HAMMER AND SMACKED THE EDGE OF THE FLYWHEEL TWO HITS AND IT CAME FREE SAME PRINCIBLE AS FROZE BRAKE SHOES IN WINTER ON SEMI HIT THE DRUM AND IT RINGS LIKE A BELL BREAKING THE BOND
When the 2N'S and the 9N'S were shipped from the factory, there was a piece of wood to hold the clutch pedal down to stop them from sticking. Now if it is going to be stopped overnight or longer I would block the clutch pedal down to prevent it sticking. Hope this helps.
Most will break loose if you wire the pedal down, then put them in a high gear and rock the tractor back and forth.I just did it
to a 621.
