unloading problems jd 7720
dsfarms13108
New User
having problems unloading jd 7720 -twisted off front bin auger -replaced auger and now it wont engage to unload -checked over chains and other augers -everything looks great -replaced shear bolts -any suggestions ? need to get soybeans done !!!!!
Look under the seat...make sure the belts and linkage are intact...make sure pulley and unloading shaft are turning together....check the shear-bolt on right-hand side big gear(probably what's wrong here)...check the front little gear to make sure the key isn't sheared
