1936 AC WC transmission cork seals input and output shaft
I am trying to find replacement seals for the transmission on my 1936 Allis chalmers wc. There are currently two cork seals on the input shaft where it goes through the bell housing and there is a cork sealing ring in the output shaft seal collar. Not getting any help from local agco dealer. Any help is appreciated. I have found replacement rubber seals for the bell housing but they are for the wd which doesn't have the scroll cut on the input shaft.
the front seal that's behind the throwout bearing carrier should be a felt seal wirh a metal retainer in front of it
AGCO #70202086 (see picture below)
the large back cork seal (7020860) is obsolete at AGCO but is being reproduced by a great man to deal with by the name
of Norm Mienert, his number is Tel: 815-865-5372, Cell: 815-238-4506
<a href="http://s33.photobucket.com/user/Joecdeere/media/1941%20WC/inputsealretainer.jpg.html" target="_blank">
</a>
Ok thanks, that's a big help. However, my plate behind the throwout bearing is different than the one you show. Attached is a picture of the cork pieces that were on the input shaft behind the throwout bearing sleeve/plate
IIRC I replaced that with something that might be called "well seal". Go to a well man and ask for it. It looks like cord, comes in various sizes, and is impregnated with a slippery substance, usually silver in color. Buy it by the inch.
