Looking at a white 2-105 and noticed it was low on hydro and the 3 speed was low, didn't want to shift into over in some gears. Ive heard they are touchy if you run them low on oil. I was wondering
what the 3 speed could cost in repair. Is the 3 speed bad? It leaks some oil, but not sure at what rate is this a deal breaker? motor runs good. I want to pull the trans/gear oil and see if its over full
from the 3 speed leaking by, there is a seal between them right?
