Hydraulic leak on 981 ford
gooseroller
New User
I have a hydraulic leak on my 981, it appears to be leaking from the gasket between the hydraulic pump and the tube that is attached at the bottom of the pump. I ordered the gasket kit from here but it looks like only 1 gasket is for the tube but the tube has 2 ends, one that attaches to the pump and the other that attaches to the bottom of the tractor. Does anyone know where I can get the other gasket? can I just get gasket material and make a duplicate because they look the same. Has anyone done this, it looks simple enough are there any tricks that I need to know? This is my first tractor and my first repair attempt, thanks for any advice you can offer.
As Bob says, O-rings only, no gaskets. Not only that but it is recommended on this forum that you use only O-rings from CNH for this particular application.
