Needing help with 1949 8-N hydraulics! It will keep a light( 150 lb)implement up but will bleed off! Will not lift a two blade plow or brush hog anymore!
Drained and refilled with 5 gal of hydraulic and transmission fluid!
Removed right side dip stick inspection plate!No leaks and I have movement in the center of the pump while the p.t.o is engaged and running!
What should I check next ZANE???
