2 left hand tie rod ends instead of 1 right & 1 left.
fhernandez
New User
I mistakenly ordered 2 left hand tie rod ends on here instead of a left and a right. Will it work if I try and use both left hand threads or should I get the right hand as well?
All depends on if both have the correct tread type. Some for being able to adjust have a left hand and right hand treading ad if that is the case NO it will not work because a right hand tread will not tread up to a left hand tread
A left hand tie rod will not screw into a tube made for RH threads. You you have to cut the end off and weld on a LH threaded nut
to make it work. best to just order the correct part.
